performance graph not load when upgrade to 5.11.3
Post Reply
dimsum
Post by dimsum »
I have a problem with the performance graph with the name in space e.g. abc123 is working but abc 123 is not working see my picture ss.
My point: If the hostname has space all of the service is not working. It has affected with old host and the new host also.
Any idea please advise.
danderson
Re: performance graph not load when upgrade to 5.11.3
Post by danderson »
Thanks for reaching out,
This is a known bug and is being worked on.
vlions
Post by vlions »
Do you have an update for us yet?
It is not solved in the new version 2024R1, it doesn't seem like a very difficult problem to me.
sgardil
Post by sgardil »
We do not give an time frame for updates as there are many things being worked on. If you would like to keep an eye out for a potential fix then you can check out our change log whenever new versions are released.
https://www.nagios.com/changelog/
vappukuttan
Post by vappukuttan »
I am hoping this is being worked on as a priority bug. Not sure why this would not be on the top of the list (and why it didnt come out in the 2024R1 already). How can you work/use Nagios XI, if the timeline/performance graphs are broken.
Atleast a work-around or steps to put a work-around would be great.
Vinod
gwesterman
Post by gwesterman »
Hi y'all,
To fix this issue, you can edit the file
nagiosxi/html/includes/components/graphexplorer/graphexplorer.inc.php
and add the line
$host = pnp_convert_object_name($host);
to line 97. Between these two chunks of code:
// Bail if we don't have permissions
if (!is_authorized_for_host(0, $host) && !is_authorized_for_service(0, $host, $service)) {
    return;
<-- PUT CODE HERE -->
//clean input
$host = urlencode($host);
$service = urlencode($service);
$service = empty($service) ? '_HOST_' : $service;
If you don't feel comfortable making this change, the fix will be in XI 2024R1.0.1.
Thank you!
vappukuttan
Thank you very much. My Nagios XI instance is good again :).
Thank you,
Post Reply
