get notification from router or switch
is it possible to receive a notification that a change has occurred after a change is made in the router or switch?
swolf
Re: get notification from router or switch
Hi @naduns, thanks for reaching out.
At the moment, NNA is primarily a Netflow analysis tool - you would be able to monitor changes in traffic, but you would probably want to rely on a different tool for configuration management and/or configuration change notification.
