Having trouble installing plugin
benningtonr
Post by benningtonr »
I am trying to use a Barracuda plugin, we had an incident yesterday that I want to monitor.
I have the pluging downloaded, i see it in the correct dir. but how do you start to monitor something without a wizard.
Re: Having trouble installing plugin
Here is a document to get you going with plugins
http://library.nagios.com/library/produ ... -nagios-xi
benningtonr
I tried it, and got the command to work at the cli,
[root@nagios libexec]# ./sgichk_cuda_queues.pl -H 64.5.129.4 -C public -2
OK: Queues and Average Latency are ok | inQueue=0 outQueue=85 deferQueue=84 notifyQueue=0 avgLatency=2
inQueue=0
outQueue=85
deferQueue=84
notifyQueue=0
avgLatency=2
I created the command, but was usure about the usr and the arg's how many to include.
The above info is alli need to monitor and be notified if one or more is exceeded.
I created the service, and was unsure what host to select, because the barracuda is not one of the hosts available yet, also what to put in for the arg's
i tried a few different things and after I hit apply it failed,
'/usr/local/nagios/etc/services/localhost.cfg'...
Error: Invalid max_attempts, check_interval, retry_interval, or notification_interval value for service 'Barracuda Queue' on host 'localhost'
Error: Could not register service (config file '/usr/local/nagios/etc/services/Barracuda.cfg', starting on line 14)
Ok, first you will need to add the host for 64.5.129.4
Next, you will need to edit the Barracuda Queue service and be sure you include values for
max_attempts,
check_interval,
retry_interval,
you can look at one of your other services for defaults
As for what to put in the $ARGn$ it will depend on how you setup your command. What did you use for the command line?
Go to Core Config Manager->Services->find the "Barracuda" service->Modify and add valid max_attempts, check_interval, retry_interval, and notification_interval values under the "Check Settings" and "Alert Settings" tabs. Click on "Save" and "Apply Configuration".
benningtonr
I put:
sgichk_cuda_queues.pl $ARG1$
I was unsure if I needed the $USR$ or if I needed more $ARG2$ etc....
Do i need a ARG for each thing it looks at?
OK: Queues and Average Latency are ok | inQueue=0 outQueue=72 deferQueue=71 notifyQueue=0 avgLatency=4
inQueue=0
outQueue=72
deferQueue=71
notifyQueue=0
avgLatency=4
benningtonr
lmiltchev wrote:Go to Core Config Manager->Services->find the "Barracuda" service->Modify and add valid max_attempts, check_interval, retry_interval, and notification_interval values under the "Check Settings" and "Alert Settings" tabs. Click on "Save" and "Apply Configuration".
I deleted the service already. But I will recreate
benningtonr
scottwilkerson wrote:Ok, first you will need to add the host for 64.5.129.4
I tried creating the host, name desc, ip address and I got the following error, and failure when I tried to apply the config
Error: Invalid max_check_attempts value for host 'Barracuda'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/Barracuda.cfg', starting on line 14)
benningtonr
ok, host created successfully
benningtonr
OK, service is created, I am getting the following
Host check is pending...
and
(Return code of 127 is out of bounds - plugin may be missing)
