Where are the dashboards stored?
Post Reply
rhassing
Post by rhassing »
I have an old installation of nagios logserver (POC) where I created some dashboards.
This installation in not working anymore. Elasticsearch won't start.
Is it possible to find and download the dashboards somewhere on this server?
Brgds,
Rob
Rob Hassing
swolf
Re: Where are the dashboards stored?
Post by swolf »
Hi @rhassing, thanks for reaching out.
All data in Nagios Log Server is stored in Elasticsearch - dashboards are stored in the kibana-int index.
If you are able to start Elasticsearch but still need to export via the terminal, you can try the following query to export your dashboards:
curl 'localhost:9200/kibana-int/_search?size=999'
Post Reply
