Monitor host B from host A nagios xi command
Post Reply
rambertnala
Post by rambertnala »
Hi friends.
I would like to implement a check that can ping host B from host A (both are Windows Server) through a check command sent by Nagios XI.
I have enabled checknet module to use check_ping plugin. Command would be
check_nrpe -H Host_A -c check_ping -a host=Host_B "critical=(time > 20 or loss > 10)"
Is there any place where i could get examples from this plugin???
In my case i wanna 10 packets sent and get critical if 10% lost packets or time > 20ms
If i use sent=10 the answer is fast like no 10 packets sent...
Any help???
Regards
lgute
Re: Monitor host B from host A nagios xi command
Post by lgute »
Hi @rambertnala, thanks for reaching out.
The NRPE documentation is available at https://support.nagios.com/kb/category.php?id=10
In the NRPE documentation there are examples and Use cases at https://support.nagios.com/kb/category.php?id=160
-Laura
rambertnala
Hi @lgute
In this case checknet is a module from nsclient. In my case Nsclient version 0.5.2.35. I wanna use check_ping from this module and option sent 10 packets
Post Reply
