I have a problem with ndo and large installations, when I restart the nagios process the information in database appears completed in more than 2 minutes, exists any way to speed this?
ndo in large installations
Re: ndo in large installations
Hi @pepe_carlos, thanks for reaching out.
Aside from adding better hardware to speed up mysql and ndo themselves, there isn't much to do from a user's point of view. NDO is currently the performance bottleneck for the whole system. It's definitely on our radar as far as backend-focused work goes, we're just more focused on frontend work at the moment.
Developer @ Nagios 2017-05-15 thru 2024-08-06
Ok, thank you for your answer.
Even so, exists any way to do that ndo not delete the previous database records every time that nagios process is restarted?
Thanks.
Thanks.
