NagiosXI | Non-SSL External Views
Post Reply
snapier3
Post by snapier3 »
I am trying to create screens to link a couple of Plotly-Dash apps that are running in local WSGI Server.
When configuring these apps as views:
XI times out and does not load the view when trying the Non-SSL URL.
http://hostname:8080 <--- fails
Works fine with SSL
https://hostname:8080 <--- works
Is this by design?
--SN
jmichaelson
Re: NagiosXI | Non-SSL External Views
Post by jmichaelson »
Hi @snapier3,
Are you using the same host in these cases? Just wondering since you're referencing both SSL and non-SSL with the same port number? Only one will work at a time for a given host and port, and if the server is expecting an SSL connection and is getting a non-SSL connection the timeout would be normal.
-Jason
snapier3
Post by snapier3 »
No I was starting the app with different configurations for each of the tests.
Test 1, http only was running port 8080 with no SSL context configured for Flask app.
Test 2, https running on port 8080 with SSL context configured for Flask App
--SN
snapier3
Post by snapier3 »
The same behavior with using NRDP URL vs external app to remove any variables that may be introduced there.
http://nagiosserver/nrdp <--- fails
https://nagiosserver/nrdp <--- works
jmichaelson
Next question. Are you using SSL on your XI server? If so, embedding non-SSL items within a page isn't going to work on a browser because of browser security policies regarding secure pages loading unsecure content.
-Jason
Post Reply
