Disable up notification on host and services
Post Reply
rfullermarsh
Post by rfullermarsh »
Whenever Nagios alerts it sends two notifications, one on the issue and one with the state as up. How can I stop the state 'up' notification?
amarosimpi
Re: Disable up notification on host and services
Post by amarosimpi »
Should be able to just select Warning/Critical and not Recovery on the service/host check:
cnorell
Developer
Post by cnorell »
rfullermarsh,
As amarosimpi mentioned, you can drill into the notification settings for individual hosts and services in the Core Config Manager to disable recovery notifications.
Additionally, this can be configured on a system level by navigation to Admin > Notification Management > Notification Preferences.
Best Regards,
Cory Norell
Rueben65
Post by Rueben65 »
rfullermarsh wrote: Fri Dec 08, 2023 12:19 pm Whenever Nagios alerts it sends two notifications, one on the issue and one with the state as up. How can I stop the state 'up' notification?
instagram story download
Adjust Nagios notification settings to exclude 'up' state notification for streamlined alert management.
rfullermarsh
Thanks for the responses but I still get the up notifications.
I never had the notify on recovery selected in preferences.
Any additional assistance would be appreciated.
jsimon
Post by jsimon »
Hi @rfullermarsh,
Are you able to provide screenshots of the CCM settings for this host/service, or the config file in question so that we can take a look at your settings and advise what to change?
Post Reply
