Nagios XI failed installation on ./B-installxi
Post Reply
kobylevy
Post by kobylevy »
facing problem with ./B-installxi section on the installation procedure.
getting:
Database Error: Could not connect to database
The server requested authentication method unknown to the client
seems issue with install_configwizard.php and DB connect, but i dont see any attemp to connect to mysql.
please advice.
Koby
kvang
Re: Nagios XI failed installation on ./B-installxi
Post by kvang »
Hi kobylevy,
Looks like someone had a similar case here. Take a snapshot before attempting this fix.
Which distro and which version of XI are you trying to install or upgrade from?
Post Reply
