Installing vSphere CLI 6.7.0 build-8156551 for Linux.
Post Reply
ithwhip
Post by ithwhip »
just downloaded ovf file and install fails
WARNING: The http_proxy environment variable is not set. If your system is
using a proxy for Internet access, you must set the http_proxy environment
variable .
If your system has direct Internet access, you can ignore this warning .
WARNING: The ftp_proxy environment variable is not set. If your system is
using a proxy for Internet access, you must set the ftp_proxy environment
variable .
CPAN not able to install following Perl modules on the system. These must be
installed manually for use by vSphere CLI:
Path::Class 0.33 or newer
UUID 0.27 or newer
Net::INET6Glue 0.603 or newer
jsimon
Re: Installing vSphere CLI 6.7.0 build-8156551 for Linux.
Post by jsimon »
Hi @ithwhip,
Unless I'm misunderstanding your post, I don't believe this is related to a Nagios product. Please correct me if I am wrong, and advise what information you are looking for on this topic.
Post Reply
