Mass change service notifications
kbauma01
Post by kbauma01 »
Hey all,
I am using Nagios XI 2024R1 and I have some AIX systems that are in XI and I need to change all their disk notifications to alert on CRITICAL only. Is there a command line way to do this?
I tried doing the Enterprise Bulk Modifications Tool-->Change a Single Config Option, added the servers and it didn't seem to take.
jsimon
Re: Mass change service notifications
Post by jsimon »
Hi @kbauma01,
There is not a simple command line way to do what you're trying to do -- if you want to manually manage your Core Config Files, I would reference this document to make sure your changes are correctly applied:
Otherwise for the Bulk Modifications tool, you mention you added your servers, but did you also add the services from those servers that you want to modify? You'll want to make sure to select the correct services before applying changes.
kbauma01
Post by kbauma01 »
Thanks for the reply @jsimon. That helped.
