Con't contact LDAP server when using AD integration with cert
Post Reply
scheived
Post by scheived »
I'm attempting to set up Nagios log server AD Integration with a self signed ca cert on the domain controller.
Server Type: Active Directory
Encryption Method SSL/TLS
Added domain certificate
When I log in I'm receiving message Can't contact LDAP server.
scheived
Re: Con't contact LDAP server when using AD integration with cert
Post by scheived »
I've verified I can get to the domain controller with,
nmap domain controller -p 636
Host is up (0.00024s latency).
PORT STATE SERVICE
636/tcp open ldapssl
Nmap done: 1 IP address (1 host up) scanned in 0.10 seconds
scheived
Post by scheived »
Done everything I can think of.
Tried importing the domain cert multiple different ways including with the domain servers local cert
Tried using ldap as well as adding the cert to openldap's cert store
Changing Encryption Method to none the user is able to log in but not SSL/TLS
I assume other people are doing activedirectory integration how are you doing it?
jsimon
Post by jsimon »
Hi @scheived,
Can you advise what Linux distro and version you are using? We have some troubleshooting steps that we can advise for AD issues, but there is a bug with the troubleshooting process on specific Enterprise Linux distros that we have a fix underway for. Knowing this would help in determining next steps.
If you are on Enterprise Linux 7 or older, or are on a Linux distro that is NOT using php-fpm, I would recommend following these steps to enable AD debugging, which should give you more insights.
https://nagiosenterprises.my.site.com/s ... n-4057bf19
Let us know if this doesn't work for you, or if you have any other questions.
Post Reply
