I'm still using NDO2 because I have performance issues with NDO3.
Support recommend me for my setup to stay at NDO2.
with the XI 2024R1, is it still possible to used NDO2? Should I used NDO3?
Nagios XI 2024R1 vs NDO2 / NDO3
- jmichaelson
Re: Nagios XI 2024R1 vs NDO2 / NDO3
I believe that a fresh install will use NDO3, judging from the scripts, but if you're using NDO2, an upgrade should leave that in place.
-Jason
-Jason
It have leaved it in place, thanks
