Upgrade to 2024R1 give error ERROR 1146 (42S02) at line 4: Table 'nagiosxi.xi_meta' doesn't exist
Post Reply
Psihawk
Post by Psihawk »
Upgrading to latest version via GUI ends with error that shows
Any thoughts? Current version we are on is: 5.9.3
Database: mysql Ver 15.1 Distrib 5.5.60-MariaDB, for Linux (x86_64) using readline 5.1
Psihawk
Re: Upgrade to 2024R1 give error ERROR 1146 (42S02) at line 4: Table 'nagiosxi.xi_meta' doesn't exist
Post by Psihawk »
Actual ran a db repair and now it dies here in the upgrade
Done!
INSTALL: Dashlets installed/updated OK.
tr: write error: Broken pipe
tr: write error
ERROR 1396 (HY000) at line 2: Operation CREATE USER failed for 'dbmaint_nagiosxi'@'localhost'
sgardil
Post by sgardil »
Hey @Psihawk
While we look into this issue can you let us know what distribution of linux you are on so we can also test to see if its distro specific? Thanks for posting your findings.
Post Reply
