We have since last year an issue with our Nagios server.
It was not monitoring any services anymore and the last checked date was far in the past. After reboot of the services the GUI was not accessible anymore. When we check the service, it should the error "No space left on device".
In the end we found a lot of old log files in the folder /usr/local/nagios/var/archives and removed them. After reboot the services were ok again and the GUI worked again.
Unfortunately the joy was only short lived because now the services are not monitored again. I checked again the archives folder but there were not that many new files created that would take up all diskspace. I removed a few and rebooted the services but still the below same error.
Can you help me further with this? What can I check or clean up more here?
Nagios Core 4.4.9
Last Modified: 2022-11-16
License: GPL
Reading configuration data...
Read main config file okay...
WARNING: The normal_check_interval attribute is deprecated and will be removed in future versions. Please use check_interval instead.
WARNING: The retry_check_interval attribute is deprecated and will be removed in future versions. Please use retry_interval instead.
Checking objects...
Checked 526 services.
Checked 241 hosts.
Checked 16 host groups.
Checked 0 service groups.
Checked 4 contacts.
Checked 1 contact groups.
Checked 57 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 241 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Error: Unable to write to temp_path ('/tmp') - No space left on device
Error: Unable to write to check_result_path ('/usr/local/nagios/var/spool/checkresults') - No space left on device
Total Warnings: 0
Total Errors: 2
***> One or more problems was encountered while running the pre-flight check...
directives and data definitions. If you are upgrading from a previous
This is the result of the df command:
ubuntu@RSB-VWA-T-MON:~$ df -h
tmpfs 781M 3.1M 778M 1% /run
/dev/mmcblk0p2 59G 50G 6.8G 88% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/mmcblk0p1 253M 122M 131M 49% /boot/firmware
tmpfs 781M 4.0K 781M 1% /run/user/1000
Re: No space left on device
ptran,
The more hosts and services being monitored the more logs XI will create, unfortunately. One option would be to create a cron job that will clean up the directories in question - so long as you don't care about the logs.
Are you taking scheduled backups? If you are, these can take up a significant amount of disk space as well.
Here's an article that goes over this issue with some solutions: https://nagiosenterprises.my.site.com/s ... r-202120ec
Best Regards,
Cory Norell
Best Regards,
Cory Norell
This is a legacy system of our previous system admin who has left the company and there is not much info about it.
I don't think there is a scheduled backup of the system as I cannot find back any /store folder back in the file system.
I already deleted all the files except the latest one from the folder "/usr/local/nagios/var/archives/" but still the system complains there is not enough diskspace. What else can I clean more?
Are there other places where log files are kept further? Is there a command that I can use to list for new log files being created somewhere else? The current folder "/usr/local/nagios/var/spool/checkresults" is already empty and the folder "/tmp" contains an old folder from last year but I am not able to view the content of this folder and also not able to delete the folder.
ptran,
Here's a document on log file locations: https://assets.nagios.com/downloads/nag ... ptions.pdf
You can check the scheduled backup setting by navigating to Admin > System Backups > Scheduled Backups
Here's a document on scheduled backups: https://support.nagios.com/kb/article.p ... %20removed.
As another option, you could try to find the highest disk usage directories on your server by running the following command:
Hopefully some of that helps.
Best Regards,
Cory Norell
du -a /home | sort -n -r | head -n 5Best Regards,
Cory Norell
Thank you for your answer.
I used the command "du -a /home" and found the folder /home/nagios/gammu/sent back that contained a lot of old SMS messages. I removed the files in this folder and now the nagios services could be started without a space issue.
Thanks for your help.
The Nagios services have run ok for a day and now again we have the same disk space issue.
I ran de du command again and it comes with different folders. I checked them out but cannot find much to clean up this time. I am wondering what is eating up all the free diskspace that I am clearing each time?
ubuntu@RSB-VWA-T-MON:~$ du -a /home | sort -n -r | head -n 5
59452 /home
57444 /home/ubuntu
15988 /home/ubuntu/.cache
15980 /home/ubuntu/.cache/go-build
15600 /home/ubuntu/gorepo
59452 /home
57444 /home/ubuntu
- jmichaelson
Let's try that du command again, but from the root directory, and go a few lines deeper in the output:
du -a /home | sort -n -r | head -n 20
-Jason
-Jason
Do you mean with the below command? This is what I get then.
ubuntu@RSB-VWA-T-MON:~$ du -a / | sort -n -r | head -n 5
du: cannot read directory '/sys/kernel/tracing': Permission denied
du: cannot read directory '/sys/kernel/debug': Permission denied
du: cannot read directory '/sys/fs/pstore': Permission denied
du: cannot read directory '/sys/fs/bpf': Permission denied
du: cannot read directory '/root': Permission denied
sort: cannot create temporary file in '/tmp': No space left on device
Filling up a filespace isn't really a nagios issue and the following message isn't very hard to understand.
Nagios services is the only thing that runs on this appliance and why is this not a nagios issue? I need to know where the system is creating new files and which files are cloching up the system after I have cleared some old files.
