Nagios Upgrade
mbrown1985
Nagios Upgrade
When I try performing the latest updates I get the attached error message that it wasn't able to perform the update. I then follow the instructions for updating manually and get an error that the assets site isn't trusted. Please see the attached screen shots. Thank you.
Re: Nagios Upgrade
Hi mbrown1985,
Thank you for getting in touch! Have you already attempted to follow the instructions outlined in this guide: https://assets.nagios.com/downloads/nag ... ctions.pdf
Additionally, could you provide information on the distro being used and version of Nagios XI you currently have installed? As well as the version to which you intend to upgrade?
Thanks!
Thanks!
- jmichaelson
Re: Nagios Upgrade
when i try to go to this link https://146.112.47.27/downloads/nagiosxi/upgrade.sh in a browser, and inspect the certificate, it tells me that the certificate is issued to all subdomains of opendns.com. It looks like somewhere in your configuration you're using opendns, either as a dns server, or as a proxy, and in either case you may not be able to control that manually.
Can you try to grab the upgrade.sh script from a browser that may be more capable than wget, using the assets nagios.com link, and scp it to the target machine? Or does a browser complain that the certificate is untrusted as well. If so you should be able to see the certificate status in the browser and see if you're seeing the same thing I am.
-Jason
-Jason
