NagiosXI index.php doesnt show any information
Post Reply
asanteben
Post by asanteben »
HI,
After an upgrade , i dont receive any info on my home page dashboard, neither on operation center view or tactical..
they can load any info averything appear at 0
(see print screen ) but with http://localhost/nagios/ i can see them...
also add some log erros may be can help.. :?:
Anybody can help to resolve this issue pls..?
swolf
Re: NagiosXI index.php doesnt show any information
Post by swolf »
Hi @asanteben, thanks for reaching out.
Can you check /usr/local/nagios/var/nagios.log for errors? Specifically, I've seen a few people get errors like this recently:
[1705332165] NDO-3: NDO 3.1.0 (c) Copyright 2009-2023 Nagios - Nagios Core Development Team
[1705332165] NDO-3: Unable to connect to mysql. Configuration may be incorrect or database may have temporarily disconnected.
[1705332165] NDO-3: NDO was not able to initialize the database (main context) and will not start.
If you find this error, check the password in /usr/local/nagios/etc/ndo.cfg. It should be the same as the password for ndoutils in /usr/local/nagiosxi/html/config.inc.php, around line 60. If the passwords don't match, try to use the one in the PHP file and then run service nagios restart.
Let me know if that helps - if you don't have that specific error, I'd still like to see if there are any other problems in nagios.log.
asanteb
Post by asanteb »
I have this as error in the log file isnt the same but its NDO-3 error...
dose it make cense to you..? :?
and i have checked the password on both files. they are the same..
[1705359601] NDO-3: ndo_return = 1 (Statement not prepared)
[1705359601] NDO-3: ndo_handle_external_command(ndo-handlers.c:1421): Unable to bind parameters
[1705359601] SERVICE ALERT: B403B;SNMP Traps;OK;HARD;1;A linkDown trap signifies that the SNMP entity, acting in 23 up down 1/23 / ifIndex.23 (INTEGER32):23 ifAdminStatus.23 (INTEGER):up ifOperStatus.23 (INTEGER):down ifName (OCTETSTR):1/23
[1705359601] SERVICE ALERT: B1004B;SNMP Traps;OK;HARD;1;A linkDown trap signifies that the SNMP entity, acting in 327 up down 6 7 / ifIndex.327 (INTEGER32):327 ifAdminStatus.327 (INTEGER):up ifOperStatus.327 (INTEGER):down enterprises.45.1.6.15.1.1.1.2.327 ():6 enterprises.45.1.6.15.1.1.1.3.327 ():7
[1705359601] SERVICE ALERT: B403B;SNMP Traps;OK;HARD;1;A linkUp trap signifies that the SNMP entity, acting in an 212 up up 4/20 / ifIndex.212 (INTEGER32):212 ifAdminStatus.212 (INTEGER):up ifOperStatus.212 (INTEGER):up ifName (OCTETSTR):4/20
[1705359601] SERVICE ALERT: B1004B;SNMP Traps;OK;HARD;1;A linkUp trap signifies that the SNMP entity, acting in an 327 up up 6 7 / ifIndex.327 (INTEGER32):327 ifAdminStatus.327 (INTEGER):up ifOperStatus.327 (INTEGER):up enterprises.45.1.6.15.1.1.1.2.327 ():6 enterprises.45.1.6.15.1.1.1.3.327 ():7
[1705359601] SERVICE ALERT: B403B;SNMP Traps;OK;HARD;1;A linkUp trap signifies that the SNMP entity, acting in an 23 up up 1/23 / ifIndex.23 (INTEGER32):23 ifAdminStatus.23 (INTEGER):up ifOperStatus.23 (INTEGER):up ifName (OCTETSTR):1/23
[1705359601] SERVICE ALERT: B102;SNMP Traps;OK;HARD;1;A linkUp trap signifies that the SNMP entity, acting in an 113 up up 2 49 / ifIndex.113 (INTEGER32):113 ifAdminStatus.113 (INTEGER):up ifOperStatus.113 (INTEGER):up enterprises.45.1.6.15.1.1.1.2.113 ():2 enterprises.45.1.6.15.1.1.1.3.113 ():49
[1705359601] SERVICE ALERT: B102;SNMP Traps;OK;HARD;1;A linkDown trap signifies that the SNMP entity, acting in 113 up down 2 49 / ifIndex.113 (INTEGER32):113 ifAdminStatus.113 (INTEGER):up ifOperStatus.113 (INTEGER):down enterprises.45.1.6.15.1.1.1.2.113 ():2 enterprises.45.1.6.15.1.1.1.3.113 ():49
[1705359602] NDO-3: ndo_return = 1 (Statement not prepared)
[1705359602] NDO-3: ndo_handle_external_command(ndo-handlers.c:1421): Unable to bind parameters
[1705359602] SERVICE ALERT: B1004B;SNMP Traps;OK;HARD;1;A linkUp trap signifies that the SNMP entity, acting in an 327 up up 6 7 / ifIndex.327 (INTEGER32):327 ifAdminStatus.327 (INTEGER):up ifOperStatus.327 (INTEGER):up enterprises.45.1.6.15.1.1.1.2.327 ():6 enterprises.45.1.6.15.1.1.1.3.327 ():7
[1705359602] SERVICE ALERT: B1004B;SNMP Traps;OK;HARD;1;A linkDown trap signifies that the SNMP entity, acting in 327 up down 6 7 / ifIndex.327 (INTEGER32):327 ifAdminStatus.327 (INTEGER):up ifOperStatus.327 (INTEGER):down enterprises.45.1.6.15.1.1.1.2.327 ():6 enterprises.45.1.6.15.1.1.1.3.327 ():7
[1705359602] SERVICE ALERT: B102;SNMP Traps;OK;HARD;1;A linkUp trap signifies that the SNMP entity, acting in an 113 up up 2 49 / ifIndex.113 (INTEGER32):113 ifAdminStatus.113 (INTEGER):up ifOperStatus.113 (INTEGER):up enterprises.45.1.6.15.1.1.1.2.113 ():2 enterprises.45.1.6.15.1.1.1.3.113 ():49
[1705359602] SERVICE ALERT: B102;SNMP Traps;OK;HARD;1;A linkDown trap signifies that the SNMP entity, acting in 113 up down 2 49 / ifIndex.113 (INTEGER32):113 ifAdminStatus.113 (INTEGER):up ifOperStatus.113 (INTEGER):down enterprises.45.1.6.15.1.1.1.2.113 ():2 enterprises.45.1.6.15.1.1.1.3.113 ():49
[1705359602] NDO-3: ndo_handle_host_status(ndo-handlers.c:1059): Unable to bind parameters
[1705359607] NDO-3: ndo_return = 1 (Statement not prepared)
[1705359607] NDO-3: ndo_handle_host_status(ndo-handlers.c:1059): Unable to bind parameters
[1705359614] NDO-3: ndo_return = 1 (Statement not prepared)
[1705359614] NDO-3: ndo_handle_host_status(ndo-handlers.c:1059): Unable to bind parameters
Post Reply
