Define parent to multiple hosts
acquala
Post by acquala »
How, if possible, can one define a parent for multiple hosts? I've looked and searched here and elsewhere but failed to find it. Thank you in advance.
gwesterman
Re: Define parent to multiple hosts
Post by gwesterman »
Hi @acquala,
In the CCM, you can navigate to Host Management for any of your hosts and add any other host as a parent under Manage Parents. This does require individually selecting each host. If you have an Enterprise License, you can use the Bulk Modifications Tool (CCM -> Tools -> Bulk Modifications Tool) and add parent(s) to multiple hosts at once. This allows you to quickly define a parent for any number of hosts.
Hope this helps! Let us know if you have any other questions.
Thank you.
acquala
Post by acquala »
Thank you for the quick and helpful reply, gwesterman! You have solved my issue. Have a great day.
gwesterman
Glad I could help! Thank you!
