Check_sip Plugin
Carlos
Check_sip Plugin
Post by Carlos »
Greetings everyone.
Im having some trouble with check_sip plugin for nagios core, under a Debian.
Using the plugin directly will result in OK replys, no problem in this.(../check_nrpe -u sip:validuri@sipserver)
When I configure nagios for doing it, the reply I get is "Unknown error: SIP/2.0 416 Unsupported URI scheme, 0.052634 seconds response time"
I defined the command, service, no alerts in the -v check, and using check_nrpe!-u sip:validuri@sipserver under linux.cfg still getting this error.
Anyone could lend me a hand here?
Thanks in advance.
Regards.
Carlos.
Carlos
Re: Check_sip Plugin
Post by Carlos »
After some research got it solved.
Service define was incomplete, if anyone have ever this problem ensure that:
check_command check_sip!sip:URI@server
Under services.cfg
Post by slansing »
Glad you found a solution, and thank you for the info!
