ever sind installing some additional prereqs for a nagios plugin the following maps will not work
Google Maps
HyperMap
NagVis
For instance if I click on HyperMap, nothing happens. In IE I get a warning in the bottom left corner with the following message (see attachment)
"Error on Page"
Syntexerror Row 60
Object Expected
Perhaps its a conflict, however I am no Linux expert and do not want to experiment and eventually risk damaging my installation.
Do you have any idea on what the error could be.
BTW. It does not work no matter which browser I use
Error in displaying Google Maps, HyperMap and Nagvis
Re: Error in displaying Google Maps, HyperMap and Nagvis
Not sure why a plugin would disrupt javascript functionality, which is all browser based. I'd suggest upgrade to the latest version of Nagios XI, and if you already have 3.2, go ahead and run the upgrade procedure again. This will give you a fresh copy of all of your web files.
