I have just done a reinstall of my nagios server.
We restored from our backup, but it seems that my plugins did not make the trip. is there anyway that i can restore them and their dependencies? or can I pull them from the backup server?
Also my back up server kicks in when my main server dies. last night the performance monitor and the monitoring engine stopped working.
When I restarted all of the services, my backup server has begun to flood my users with the emails it would have sent so I have disabled notifications. How can I renenbler them without nagios resending the notifications?
post migration woes.
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: post migration woes.
Can you elaborate a little bit more on "my plugins did not make the trip"? You don't have any plugins in the libexec directory or you have them but they don't work? Can you run the following command in terminal and post the output?
I would suggest fixing the plugins issue before enabling notifications. The alerts that are already in the mailing queue will be sent anyway though.
ll /usr/local/nagios/libexecBe sure to check out our Knowledgebase for helpful articles and solutions!
plugins on the rebuilt server:
total 6604
-rwxr-xr-x 1 root root 348433 Jul 24 13:57 check_apt
-rwxr-xr-x. 1 root root 6897 Jul 24 13:58 check_asterisk.pl
-rwxr-xr-x 1 root root 2274 Jul 24 13:57 check_breeze
-rwxr-xr-x 1 root root 92653 Jul 24 13:57 check_by_ssh
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_clamd -> check_tcp
-rwxr-xr-x 1 root root 50873 Jul 24 13:57 check_cluster
-r-sr-xr-x 1 root root 90337 Jul 24 13:57 check_dhcp
-rwxr-xr-x 1 root root 87773 Jul 24 13:57 check_dig
-rwxr-xr-x 1 root root 390546 Jul 24 13:57 check_disk
-rwxr-xr-x 1 root root 8163 Jul 24 13:57 check_disk_smb
-rwxr-xr-x 1 root root 96206 Jul 24 13:57 check_dns
-rwxr-xr-x 1 root root 46260 Jul 24 13:57 check_dummy
-rwxr-xr-x 1 nagios users 16747 Jul 25 15:26 check_em01
-rwxr-xr-x 1 nagios users 5625 Jul 25 15:26 check_em01.pl
-rwxr-xr-x 1 nagios users 16895 Jul 25 15:26 check_em08
-rwxr-xr-x. 1 root root 20039 Jul 24 13:58 check_email_loop.pl
-rwxr-xr-x 1 nagios users 28665 Jul 26 13:34 check_emc_clariion.pl
-rwxr-xr-x 1 nagios users 82841 Jul 25 15:37 check_esx3.pl
-rwxr-xr-x 1 root root 3143 Jul 24 13:57 check_file_age
-rwxr-xr-x 1 root root 6395 Jul 24 13:57 check_flexlm
-rwxr-xr-x 1 root root 92048 Jul 24 13:57 check_fping
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_ftp -> check_tcp
-rwxr-xr-x 1 root root 90056 Jul 24 13:57 check_hpjd
-rwxr-xr-x 1 root root 468776 Jul 24 13:57 check_http
-r-sr-xr-x 1 root root 97773 Jul 24 13:57 check_icmp
-rwxr-xr-x 1 root root 59316 Jul 24 13:57 check_ide_smart
-rwxr-xr-x 1 root root 15310 Jul 24 13:57 check_ifoperstatus
-rwxr-xr-x 1 root root 12853 Jul 24 13:57 check_ifstatus
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_imap -> check_tcp
-rwxr-xr-x 1 root root 7429 Jul 24 13:57 check_ircd
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_jabber -> check_tcp
-rwxr-xr-x 1 root root 73626 Jul 24 13:57 check_ldap
lrwxrwxrwx 1 root root 10 Jul 24 13:57 check_ldaps -> check_ldap
-rwxr-xr-x 1 root root 73506 Jul 24 13:57 check_load
-rwxr-xr-x 1 root root 6062 Jul 24 13:57 check_log
-rwxr-xr-x 1 root root 20367 Jul 24 13:57 check_mailq
-rwxr-xr-x 1 root root 59970 Jul 24 13:57 check_mrtg
-rwxr-xr-x 1 root root 58835 Jul 24 13:57 check_mrtgtraf
-rwxr-xr-x. 1 root root 11427 Jul 24 13:58 check_mssql
-rwxr-xr-x 1 root root 94383 Jul 24 13:57 check_mysql
-rwxr-xr-x. 1 root root 98711 Jul 24 13:58 check_mysql_health
-rwxr-xr-x 1 root root 86413 Jul 24 13:57 check_mysql_query
-rwxr-xr-x 1 root root 72447 Jul 24 13:57 check_nagios
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_nntp -> check_tcp
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_nntps -> check_tcp
-rwxrwxr-x 1 nagios nagios 75444 Jul 24 13:57 check_nrpe
-rwxr-xr-x 1 root root 93815 Jul 24 13:57 check_nt
-rwxr-xr-x 1 root root 96835 Jul 24 13:57 check_ntp
-rwxr-xr-x 1 root root 87051 Jul 24 13:57 check_ntp_peer
-rwxr-xr-x 1 root root 83829 Jul 24 13:57 check_ntp_time
-rwxr-xr-x 1 root root 125710 Jul 24 13:57 check_nwstat
-rwxr-xr-x 1 root root 8366 Jul 24 13:57 check_oracle
-rwxr-xr-x 1 root root 75739 Jul 24 13:57 check_overcr
-rwxr-xr-x 1 root root 69350 Jul 24 13:57 check_pgsql
-rwxr-xr-x 1 root root 99658 Jul 24 13:57 check_ping
-rwxr-xr-x 1 nagios nagios 6183 Jul 24 13:57 check_pnp_rrds.pl
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_pop -> check_tcp
-rwxr-xr-x. 1 root root 281655 Jul 24 13:58 check_postgres.pl
-rwxr-xr-x 1 root root 368712 Jul 24 13:57 check_procs
-rwxr-xr-x 1 root root 71134 Jul 24 13:57 check_real
-rwxr-xr-x 1 root root 9707 Jul 24 13:57 check_rpc
-rwxr-xr-x. 1 root root 9232 Jul 24 13:58 check_rrdtraf
-rwxr-xr-x. 1 root root 5299 Jul 24 13:58 check_rrdtraf.php
-rwxr-xr-x 1 root root 1176 Jul 24 13:57 check_sensors
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_simap -> check_tcp
-rwxr-xr-x. 1 root root 7599 Jul 24 13:58 check_sip
-rwxr-xr-x 1 root root 406354 Jul 24 13:57 check_smtp
-rwxr-xr-x 1 root root 408607 Jul 24 13:57 check_snmp
-rwxr-xr-x. 1 root root 10951 Jul 24 13:58 check_snmp_boostedge.pl
-rwxr-xr-x. 1 root root 17866 Jul 24 13:58 check_snmp_cpfw.pl
-rwxr-xr-x. 1 root root 8747 Jul 24 13:58 check_snmp_css_main.pl
-rwxr-xr-x. 1 root root 16786 Jul 24 13:58 check_snmp_css.pl
-rwxr-xr-x. 1 root root 33562 Jul 24 13:58 check_snmp_env.pl
-rwxr-xr-x. 1 root root 31919 Jul 24 13:58 check_snmp_int.pl
-rwxr-xr-x. 1 root root 10108 Jul 24 13:58 check_snmp_linkproof_nhr.pl
-rwxr-xr-x. 1 root root 22965 Jul 24 13:58 check_snmp_load.pl
-rwxr-xr-x. 1 root root 18734 Jul 24 13:58 check_snmp_mem.pl
-rwxr-xr-x. 1 root root 11898 Jul 24 13:58 check_snmp_nsbox.pl
-rwxr-xr-x. 1 root root 24233 Jul 24 13:58 check_snmp_process.pl
-rwxr-xr-x. 1 root root 24002 Jul 24 13:58 check_snmp_storage.pl
-rwxr-xr-x. 1 root root 14489 Jul 24 13:58 check_snmp_vrrp.pl
-rwxr-xr-x. 1 root root 11967 Jul 24 13:58 check_snmp_win.pl
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_spop -> check_tcp
-rwxr-xr-x 1 root root 69094 Jul 24 13:57 check_ssh
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_ssmtp -> check_tcp
-rwxr-xr-x 1 root root 74796 Jul 24 13:57 check_swap
-rwxr-xr-x 1 root root 123180 Jul 24 13:57 check_tcp
-rwxr-xr-x 1 root root 71240 Jul 24 13:57 check_time
lrwxrwxrwx 1 root root 9 Jul 24 13:57 check_udp -> check_tcp
-rwxr-xr-x 1 root root 84166 Jul 24 13:57 check_ups
-rwxr-xr-x 1 root root 68835 Jul 24 13:57 check_users
-rwxr-xr-x 1 root root 3019 Jul 24 13:57 check_wave
-rwxr-xr-x. 1 root root 307 Jul 24 13:58 check_webinject.sh
-rwxr-xr-x 1 nagios users 2405 Jul 27 14:07 check_wmi_plus.conf
-rwxr-xr-x 1 nagios users 46543 Jul 27 14:07 check_wmi_plus.ini
-rwxr-xr-x 1 nagios users 237155 Jul 27 14:07 check_wmi_plus.pl
-rwxr-xr-x 1 root root 75011 Jul 24 13:57 negate
-rwxr-xr-x 1 nagios nagios 42724 Jul 24 13:57 process_perfdata.pl
-rwxr-xr-x. 1 root root 64618 Jul 24 13:58 send_nsca
-rwxr-xr-x 1 root root 68266 Jul 24 13:57 urlize
-rwxr-xr-x 1 root root 2035 Jul 24 13:57 utils.pm
-rwxr-xr-x 1 root root 862 Jul 24 13:57 utils.sh
[root@lkennagios01 ~]#
Proudly running:
Nagios Fusion
Nagios Fusion
It looks like they "made the trip"....
What issues are you seeing?
this has been resolved. thank you .
Proudly running:
Nagios Fusion
Nagios Fusion
