I'm running NagiosXI on RHEL5, Nagios is at version 2011R1.6
I have set a new url for the application of nagios.domain.com. I am trying to disable the default servername/nagiosxi. I have been unsuccessful at disabling the default url up to this point.
Can you please assist me with direction on how to make this change?
Thank you
disable default url
Re: disable default url
Nagios XI is designed to run on with any hostname or IP on the system (including localhost), I'm not sure I understand what you are trying to accomplish.
uofcmissouri
our certificate is only valid for https://nagios.domain.com
So for security purposes I need to be able to keep users from accessing nagios on https://servername.domain.com/nagiosxi or any other url with the exception of the above. As there is no certificate for use with any additional url.
I hope that makes sense.
If you followed this doc
http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
Once you have the secure certificate working, edit /etc/httpd/conf.d/nagiosxi.conf and replace this
with this
<VirtualHost *:443>Code: Select all
<VirtualHost nagios.domain.com:443>-
uofcmissouri
I did use that document when I set up ssl.
I've already made that change in the nagiosxi.conf file, here is my config. Port 80 is actually blocked at the firewall. These changes are how I got the new url to work, but it doesn't stop https://servername.domain.com/nagiosxi from working.
<VirtualHost *:80>
<Directory "/usr/local/nagiosxi/html">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
# AuthName "Nagios XI"
# AuthType Basic
# AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
# Require valid-user
</Directory>
</VirtualHost>
SSLEngine on
SSLCertificateFile /etc/pki/tls/certs/nagios.domain.com-cert.crt
SSLCertificateKeyFile /etc/pki/tls/private/nagios.domain.com.key
SSLCACertificateFile /etc/pki/tls/certs/DOMAIN_INTERMEDIATE-G2-cacert.crt
AllowOverride All
</Directory>
</VirtualHost>
Alias /nagiosxi "/usr/local/nagiosxi/html"
<VirtualHost *:80>
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# AuthType Basic
</Directory>
</VirtualHost>
SSLEngine on
AllowOverride All
</Directory>
</VirtualHost>
I'm not an apache config expert, but would it work to do something like:
Or, you could also use apache's mod_rewrite to redirect all traffic for the old address to the new one. Preferences?
<VirtualHost nagios.baddomain.stopusingthis:443>
Deny From All
</VirtualHost>
