Installing Nagios XI on Windows 7
markshaw
Post by markshaw »
I'm trying to install Nagios XI on a Win7 box.
I have downloaded ‘Microsoft virtual machine running CentOS 6.x with Nagios XI 2011’ as per here
http://library.nagios.com/library/produ ... loads/main
However at the bottom of the page it says
‘VMware Image Notes - You'll need VMware Server or VMware Player to run the virtual machine’
So I downloaded and installed Windows Virtual PC.
Then extracted the Nagios install file - nagiosxi-2011r3.2-virtualpc.zip.
This created two files; nagios.vhd & nagiosxi.vmc.
I ran nagiosxi.vmc which opened a Windows Virtual PC window with a Nagios login prompt.
I’ve logged in to Nagios console.
What now?
The docs say to connect , go to http://<xiserver>/
How do I find the ip address of the nagios server?
Did Nagios install to the Windows Virtual PC I just installed?
Is there a document somewhere I can read for a win install? The documentation for a Windows install seem very fragmented and light on detail.
Cheers,
Mark.
yancy
Re: Installing Nagios XI on Windows 7
Post by yancy »
Hi marhshaw,
Documentation can be found in the NagiosXI Administration guide:
http://assets.nagios.com/downloads/nagi ... lingvmware
here is one on setting up the virtual machine:
http://assets.nagios.com/downloads/nagi ... _Notes.pdf
NagiosXI doesn't install on the Windows 7 machine, it comes preloaded on the VM. As long as the VM is running, NagiosXI is available.
From the login prompt, you can login with the following default credentials:
username: root
password: nagiosxi
to find the ip address, type:
 ifconfig
Hope that helps!
-Yancy
markshaw
Post by markshaw »
I ran ifconfig. The only IP Address I can see is for 'lo' and is "127.0.0.1"
So as per the pdf you quoted (which dosen't cover windows...)
http://127.0.0.1/nagiosxi
doesn't connect to anything.
I also tried my PC IP address, same result.
There are some Network settings in Windows Virtual PC.
I tried all options in the drop down list, and restarted the Virtual PC after each time, then did a ifconfig, looked for the IP addressand tried to connect via HTTP.
The last network setting in the drop down list worked, and I connected to the NagiosXI installation page.
It's all up and running now. :)
Windows Virtual PC was recommended on NagiosXI download page, so I'd expect how it configured to be mentioned in Nagios documentation
....2 days to get Nagios installed & working. Should it really be that difficult....
Thanks for you help
nscott
Post by nscott »
markshaw,
I'll have a look at the documentation, and I'm glad you got it figured out. Let us know if you have any other questions.
/Nick
Nicholas Scott
