Notification based on SLA
gm_rajkumar
Post by gm_rajkumar »
I have some criteria on sending notification on any service or node down in Nagios XI. For example a Node/Service down, Nagios starts sending mails to specific user/Group. However, if that server down for more than a hour/two hours (based on my SLA), it would triggers mail based on this Rule:
my mail notification(Recipients) might changes like escalation level1,escalation level 2 like that. Is this possible to configure in Nagios XI?
Regards,
Raj.
Re: Notification based on SLA
Post by slansing »
Yes you may do this, the procedures are covered in the following document:
http://assets.nagios.com/downloads/nagi ... ations.pdf
gm_rajkumar
Thanks, let me try and update you!! :D
Post by slansing »
Sounds good let us know. Good luck!
