Printer monitoring
cjtech
Printer monitoring
Post by cjtech »
Anyone had any success monitoring Konica Minolta printers?
All our HP printers obviously work fine with the inbuilt printer configuration wizard.
Can't find any listed - http://exchange.nagios.org/directory/Ad ... on-Wizards
mmestnik
Re: Printer monitoring
Post by mmestnik »
http://printer.konicaminolta.com/suppor ... 60_sup.htm
ftp://ftp.minolta-qms.com/pub/cts/out_g ... 560mib.exe
MIB (Management Information Base)
2560mib.exe Version: 1.8 Size: 39K Date: 01-Sept-99
Our MIB provides the full-annotated text of the SNMP set of variables used to monitor and control the printing process. For use with the 2560 Print System only.
The OIDs are likely different, just plug the new ones in. If you could put together a list of the changes and we might add this to the next version of the Wizard.
cjtech
Post by cjtech »
The date of that file looks to be pretty old, Date: 01-Sept-99
Looks to be referencing windows95 in the path as well?
Or maybe I'm not following your suggestion correctly.
TSCAdmin
Post by TSCAdmin »
The date of the MIB file is irrelevant so long as the OIDs are correct.
