changing performance graph time range
mbotier
Post by mbotier »
Hey, i want to change the time and length of the performance graph. By default its set to a min of 1 sec and a max of 5 sec. How can i change this?
nscott
Re: changing performance graph time range
Post by nscott »
Can you please rephrase your question? Is the time range its displaying 1 to 5 seconds? Is that the max bounds its displaying?
Nicholas Scott
mbotier
Post by mbotier »
yes, its displaying 1 to 5 seconds and i would like to change that........
mguthrie
Post by mguthrie »
I'm assuming the metric that you're monitoring is time in seconds?? If so, the min/max values are actually specified in the service definition for this check. If you access the Core Config Manager->Services, and locate the service definition, the min/max values are probably located in the $ARG$ fields.
