Hello everybody,
I'm a newbie with nagiosXI
I have an issue for upgrade from NagiosXI 2.4 to 3.2
Nagios is installed on centos 5.3 and install manually
The ./upgrade process run during 5min, it change a lot of think but the process finished with the following information
*** Main program, CGIs and HTML files installed ***
You can continue with installing Nagios as follows (type 'make'
without any arguments for a list of all possible options):
make install-init
- This installs the init script in /etc/rc.d/init.d
make install-commandmode
- This installs and configures permissions on the
directory for holding the external command file
make install-config
- This installs sample config files in /usr/local/nagios/etc
#make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios'
#Running configuration check...done.
#Stopping nagios: done.
#Starting nagios: done.
#Saving old crontab to /tmp/nagios.crontab.orig.3...
#no crontab for nagios
Thanks in advance for your help
Migration from 2011R2.4 to 2011R3.2 issue
Re: Migration from 2011R2.4 to 2011R3.2 issue
Hi yancy,
I execute your command and the result is:
# crontab -l
no crontab for root
# crontab -l
no crontab for root
Run the following
cd /tmp/nagiosxi
cat /dev/null > uninstall-crontab-nagios
cat /dev/null > uninstall-crontab-root
./upgrade
Hi all,
Perfect Issue resolved, thanks a lot
Just for information, Somebody can explain me why ?
Complete!
UPGRADE COMPLETED!
Complete!
UPGRADE COMPLETED!
There was a bug in our upgrade script that showed its head if there was no current data in the root crontab.
It has been fixed for future releases.
