pleaaaaaaaaaaase it's urgent
slimix00
Post by slimix00 »
I hope u’re doing great
well,
I installed NSClient++ on my windows machine (the icon exists but they tell me that nsclient++ system tray is offline, that is the first question )
1) Considering nagios server (I’m working on ubuntu) ! I installed nrpe-2.12 and the result was : check_nrpe had been added into /usr/local/nagios/libexec, knowing that It wasn’t exisiting before ( and I could became crasy before installing it) so that is good
2) in windows.cfg I’ve defined nrpe service
3) in commands.cfg I’ve defined two commands :
-nrpe with ssh
-nrpe without ssh
well the communication is established between my nagios server and my windows machine (for example I’m able to know the version of my nsclient or the CPU load of the windows machine )
so after that, sould restart my nagios but here is the problem : the second question
/etc/init.d/nagios restart
Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration.
>>>> There are too many files , ans I don’t know which one to verify and from where the mistake could come !!!
I'm so confused
Sorry my english is little bad
thank youuu
Re: pleaaaaaaaaaaase it's urgent
Post by slansing »
Hello slimix00,
You can verify your config by using:
This will provide some useful information on tracking down issues with your config files.
Also, could you post what version of Nagios you are running?
slimix00
Post by slimix00 »
the version of nagios is : 3.0.6
well I used the command that you told and it gives some informations
thank's a lot
slimix00
Post by slimix00 »
slansing you're the best
I could resolve the configuration problems
thank you soooooooooooo much
luv you
Post by slansing »
Glad you've got everything figured out!
