Nagios Nrpe issues
noodle48
Nagios Nrpe issues
Post by noodle48 »
Okay, I have both AIX and Linux (Nagios) server able to run check_nrpe -H IP and both return same version. On Nagios server I can issue the check_nrpe -H AIX IP -c check_command and I receive the correct output. But when I place the check in my services.cfg to monitor in the Nagios app I get a Error receiving data from daemon. Why is this happening, I get correct info from command line but not when the check runs inside services.cfg?
jsmurphy
Re: Nagios Nrpe issues
Post by jsmurphy »
Are you able to post up the relevant service and command definitions from your Nagios config?
