$SERVICEOUTPUT$ macro
I'm using the check_nt plugin to monitor disk space.
The output is generated with "%" sign which need to eliminate (not acceptable when sending to an some external sms provider)
I can't do by manipulating the plugin command so I thought of customize the $SERVICEOUTPUT$ and eliminiate the "%" sigh from there.
Is it possible ?
Example:
Service: Drive C: Disk Usage
Host: Inwise
Address: 10.4.10.6
State: WARNING
Info:
C:\ - total: 20.00 Gb - used: 16.53 Gb (83%) - free 3.47 Gb (17%)
Date/Time: 26/07/2012 14:47:11
Is it possible ?
Example:
Host: Inwise
Address: 10.4.10.6
State: WARNING
Info:
Re: $SERVICEOUTPUT$ macro
I'd try experimenting with wrapping the macro in either single or double quotes and see if it will let the characters through.
I need to prevent the "%'" sign from accessing the macro, eliminating afterwards want help me.
Maybe writing a macro which want accept it at the first place ? how ?
You may try to create a custom macro, which will output for example "percent" instead of "%". I am not sure how (and if) it can be done, but here is our documentation on notification variables in Nagios XI:
http://assets.nagios.com/downloads/nagi ... iables.pdf
Hope this helps.
Hope this helps.
You could use a script like this..
Save it in the libexec folder as "check_nt_sms". Then run "chmod +x check_nt_sms" to make it executable. Verify the $pathtocommand is correct. Then you can run it in place of your original command.
**Note: this is just an example. No guarantees.
####BEGIN OUTPUT EDITOR SCRIPT
#!/usr/bin/perl -w
####SET VARIABLES
$args = "";
$pathtocommand = "/usr/local/nagios/libexec/check_nt";
####COLLECT COMMAND LINE ARGS
foreach (@ARGV) {
$args .= $_ . " ";
####RUN THE COMMAND
$output = `$pathtocommand $args`;
####FILTER OUTPUT
$output =~ s/%/ percent/gi;
####PRINT THE RETURN STRING
print "$output";
####END OUTPUT EDITOR SCRIPT**Note: this is just an example. No guarantees.
CGraham,
Thanks for sharing!
Thanks for sharing!
Thanks CGraham, but your suggestion return (null) :
Aug 12 06:13:43 nagios nagios: SERVICE ALERT: Inwise;Drive D: Disk Usage;CRITICAL;HARD;2;(null)
Anyway, I did somthing simular and used "sed" on the command itself:
$USER1$/check_nt -H $HOSTADDRESS$ -s "$ARG1$" -p 12489 -v $ARG2$ $ARG3$ | sed -e 's/%/ percent/g'
This is not good as from some reason when I simulate now "WARNING" it returns "OK". maybe the % "sign" is hardcoded somewhere ?
without sed:
Aug 12 07:18:15 nagios nagios: SERVICE NOTIFICATION: _Test;Inwise;Drive D: Disk Usage;WARNING;notify-oz_test-ser
vice;D:\ - total: 10.00 Gb - used: 3.33 Gb (33%) - free 6.67 Gb (67%)
With sed:
Aug 12 07:22:10 nagios nagios: SERVICE NOTIFICATION: _Test;Inwise;Drive D: Disk Usage;OK;notify-oz_test-ser
vice;C:\ - total: 10.00 Gb - used: 3.33 Gb (33 percent) - free 6.67 Gb (67 percent)
In general, I want the save some costs by converting the SMS notifications into smartphone push notification.
So I have an external company proccess which runs in the backround and collects events.
The command which generates the event:
/usr/bin/printf "Destination:oz_test|\nSubject: $NOTIFICATIONTYPE$ : $HOSTNAME$ \nBody: $SERVICESTATE$ - $HOSTALIAS$ - $SERVICEDESC$ - $SERVICEOUTPUT$ - $HOSTADDRESS$ - $LONGDATETIME$\n\n"> `mktemp -p /usr/local/test_Nagios/eventfiles/ nagioseventfile_XXXXXXXXX`
Now, the "printf' command doesn't returns "%" so the it just cuts every thing after that sign.
the event generated:
Aug 12 07:18:15 nagios nagios: SERVICE NOTIFICATION: _Test;Inwise;Drive D: Disk Usage;WARNING;notify-oz_test-by-TeamTilt-ser
I can use the "echo" command instead of "printf" and then the event turns out ok with the "%" but somehow thier proccess won't accept it (they can't help with that).
I have tried also sed on the "SERVICEOUTPUT" inside that command but it's not working also:
usr/bin/printf "Destination:oz_test|\nSubject: $NOTIFICATIONTYPE$ : $HOSTNAME$ \nBody: $SERVICESTATE$ - $HOSTALIAS$ - $SERVICEDESC$ - $(echo $SERVICEOUTPUT$ | sed -r 's/[%]+/&&/') - $HOSTADDRESS$ - $LONGDATETIME$\n\n"> `mktemp -p /usr/local/test_Nagios/eventfiles/ nagioseventfile_XXXXXXXXX`.
I can't understand how I can customize a macro for my needs according to the below link:
I need that "SERVICEOUTPUT" to not contain any "%".
Maybe you can also help to understand why the "sed" manipulation on the "check_nt" returns "OK" instead of "WARNING"
Thanks a lot.
without sed:
With sed:
Thanks a lot.
Try changing the command to the following
usr/bin/printf "Destination:oz_test|\nSubject: $NOTIFICATIONTYPE$ : $HOSTNAME$ \nBody: $SERVICESTATE$ - $HOSTALIAS$ - $SERVICEDESC$ - $(echo $SERVICEOUTPUT$ | sed -r 's/[%]+//') - $HOSTADDRESS$ - $LONGDATETIME$\n\n"> `mktemp -p /usr/local/test_Nagios/eventfiles/ nagioseventfile_XXXXXXXXX`.Re: $SERVICEOUTPUT$ macro
Tried that already it's just puts $ on all fields after that echo.
Nagios Event:
Aug 14 09:26:50 nagios nagios: SERVICE NOTIFICATION: TeamTilt_Test;Inwise;Drive D: Disk Usage;WARNING;notify-oz_test;D:\ - total: 10.00 Gb - used: 3.46 Gb (35%) - free 6.53 Gb (65%)
Corresponded smartphone Event:
Subject: PROBLEM : Inwise
Body: WARNING - Inwise - Drive D: Disk Usage - $ - $ - $
Nagios Event:
You realize that the command I posted is different than the one you posted, right? The echo with the sed changed from
to
$(echo $SERVICEOUTPUT$ | sed -r 's/[%]+/&&/')Code: Select all
