On a system with SELinux enabled you get a Permission Denied in the error_log:
(13)Permission denied: exec of '/usr/local/nagios/sbin/tac.cgi'Files installed in /usr/local/nagios/sbin will have the default context like:
(root@nm2srvp01:/)$ ls -Z /usr/local/nagios
drwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 bin
drwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 etc
drwxr-xr-x. root root unconfined_u:object_r:usr_t:s0 include
drwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 libexec
drwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 sbin
drwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 share
drwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 var
(root@nm2srvp01:/)$ ls -Z /usr/local/nagios/sbin
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 avail.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 cmd.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 config.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 extinfo.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 histogram.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 history.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 notifications.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 outages.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 showlog.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 status.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 statusmap.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 statuswml.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 statuswrl.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 summary.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 tac.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 trends.cgiCode: Select all
(root@nm2srvp01:/)$ chcon -v --type=httpd_sys_content_t /usr/local/nagios/sbin
changing security context of `/usr/local/nagios/sbin'
(root@nm2srvp01:/)$ chcon -v --type=httpd_sys_content_t /usr/local/nagios/sbin/*
changing security context of `/usr/local/nagios/sbin/avail.cgi'
changing security context of `/usr/local/nagios/sbin/cmd.cgi'
changing security context of `/usr/local/nagios/sbin/config.cgi'
changing security context of `/usr/local/nagios/sbin/extinfo.cgi'
changing security context of `/usr/local/nagios/sbin/histogram.cgi'
changing security context of `/usr/local/nagios/sbin/history.cgi'
changing security context of `/usr/local/nagios/sbin/notifications.cgi'
changing security context of `/usr/local/nagios/sbin/outages.cgi'
changing security context of `/usr/local/nagios/sbin/showlog.cgi'
changing security context of `/usr/local/nagios/sbin/status.cgi'
changing security context of `/usr/local/nagios/sbin/statusmap.cgi'
changing security context of `/usr/local/nagios/sbin/statuswml.cgi'
changing security context of `/usr/local/nagios/sbin/statuswrl.cgi'
changing security context of `/usr/local/nagios/sbin/summary.cgi'
changing security context of `/usr/local/nagios/sbin/tac.cgi'
changing security context of `/usr/local/nagios/sbin/trends.cgi'
drwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 sbin
drwxrwxr-x. nagios nagios unconfined_u:object_r:usr_t:s0 varCode: Select all
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 avail.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 cmd.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 config.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 extinfo.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 histogram.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 history.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 notifications.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 outages.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 showlog.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 status.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 statusmap.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 statuswml.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 statuswrl.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 summary.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 tac.cgi
-rwxrwxr-x. nagios nagios unconfined_u:object_r:httpd_sys_content_t:s0 trends.cgi
