I'm setting up a new nagios install and am experiancing the error "Return code of 126 is out of bounds - plugin may not be executable" when nagios runs the perl script check_snmp_storage.pl. Reasearch on the error sugests a permission error, but the script appears to run correctly under both root and nagios users.
Script Permissions:
-rwxr-xr-x. 1 nagios nagios 25522 Aug 9 18:09 ./check_snmp_storage.plCode: Select all
command_name check_snmp_storage_test
command_line $USER1$/check_snmp_storage.pl -H $HOSTADDRESS$ -C public -m $ARG1$ -w $ARG2$ -c $ARG3$ $ARG4$
hostgroup_name windows-servers
service_description TEST SNMP Storage
check_command check_snmp_storage_test!"^/[C,D,E]"!80!90!
