I followed the upgrade document line by line including the backup! I ran the upgrade, no errors reported, but it still shows version Nagios XI 2011R2.2. I tired 3 different browsers to make sure it was not browser related ( yes I cleared the cache for the browsers) any Ideas on this?
What issues will show up and what peices may not work until I get this resolved?
Nagiosxi Upgrade using xi-2011r3.2.tar.gz
Re: Nagiosxi Upgrade using xi-2011r3.2.tar.gz
I believe this may be caused by an upgrade bug
Please run
And make sure after it completes you see
Please run
cd /tmp/nagiosxi
cat /dev/null > uninstall-crontab-nagios
cat /dev/null > uninstall-crontab-root
./upgradeCode: Select all
UPGRADE COMPLETED!
==================Re: Nagiosxi Upgrade using xi-2011r3.2.tar.gz
Thanks that worked perfectly!
Should those steps be added to the upgrade documentation
The problem has been addressed and will resolved starting 2011R3.3
