check_snmp_temperature.pl OID Issue
gshergill
Post by gshergill »
Hi Nagios Community,
I was wondering if you know what the following error is about;
./check_snmp_temperature.pl -H <dellserver>.<domain> -C public -N .1.3.6.1.4.1.674.10892.1.700.20.1.8 -D .1.3.6.1.4.1.674.10892.1.700.20.1.6 -i 10C -o C -u 0 -a Temperature -w 0 -c 0 -f
ERROR: Problem retrieving OID .1.3.6.1.4.1.674.10892.1.700.20.1.8 table: Requested table is empty or does not exist.
I'm assuming it is an issue with the OID used being wrong, but I don't really know how to find the right OID, a google search gives me the impression that the OIDs are standardly set by dell.
Note that snmp is definitely installed on the dell server, and the OID 1.3.6.1.4.1.2021.13.16 works (but gives back temperature as 0)
Thank you.
Kind Regards,
gshergill
EDIT: forgot to mention;
coolingDeviceLocationName 1.3.6.1.4.1.674.10892.1.700.12.1.8
coolingDeviceReading 1.3.6.1.4.1.674.10892.1.700.12.1.6
Re: check_snmp_temperature.pl OID Issue
Post by slansing »
Have you tried searching to make sure you have the correct OID? These are updated and changed frequently in some cases:
http://www.oidview.com/mibs/674/md-674-1.html
gshergill
Post by gshergill »
Hi slansing,
I've been using the link http://www.oidview.com/mibs/674/MIB-Dell-10892.html to find the OID numbers.
I've ran the following command with the result;
snmpwalk -v2c -cpublic <server>.<domain> system
SNMPv2-MIB::sysDescr.0 = STRING: Linux <server> 2.6.32-bpo.5-amd64 #1 SMP Mon May 2 11:40:03 UTC 2011 x86_64
SNMPv2-MIB::sysObjectID.0 = OID: NET-SNMP-MIB::netSnmpAgentOIDs.10
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (24777245) 2 days, 20:49:32.45
SNMPv2-MIB::sysContact.0 = STRING: Root <root@localhost> (configure /etc/snmp/snmpd.local.conf)
SNMPv2-MIB::sysName.0 = STRING: <server>
SNMPv2-MIB::sysLocation.0 = STRING: Unknown (configure /etc/snmp/snmpd.local.conf)
SNMPv2-MIB::sysORLastChange.0 = Timeticks: (217) 0:00:02.17
SNMPv2-MIB::sysORID.1 = OID: SNMP-FRAMEWORK-MIB::snmpFrameworkMIBCompliance
SNMPv2-MIB::sysORID.2 = OID: SNMP-MPD-MIB::snmpMPDCompliance
SNMPv2-MIB::sysORID.3 = OID: SNMP-USER-BASED-SM-MIB::usmMIBCompliance
SNMPv2-MIB::sysORID.4 = OID: SNMPv2-MIB::snmpMIB
SNMPv2-MIB::sysORID.5 = OID: TCP-MIB::tcpMIB
SNMPv2-MIB::sysORID.6 = OID: IP-MIB::ip
SNMPv2-MIB::sysORID.7 = OID: UDP-MIB::udpMIB
SNMPv2-MIB::sysORID.8 = OID: SNMP-VIEW-BASED-ACM-MIB::vacmBasicGroup
SNMPv2-MIB::sysORDescr.1 = STRING: The SNMP Management Architecture MIB.
SNMPv2-MIB::sysORDescr.2 = STRING: The MIB for Message Processing and Dispatching.
SNMPv2-MIB::sysORDescr.3 = STRING: The management information definitions for the SNMP User-based Security Model.
SNMPv2-MIB::sysORDescr.4 = STRING: The MIB module for SNMPv2 entities
SNMPv2-MIB::sysORDescr.5 = STRING: The MIB module for managing TCP implementations
SNMPv2-MIB::sysORDescr.6 = STRING: The MIB module for managing IP and ICMP implementations
SNMPv2-MIB::sysORDescr.7 = STRING: The MIB module for managing UDP implementations
SNMPv2-MIB::sysORDescr.8 = STRING: View-based Access Control Model for SNMP.
SNMPv2-MIB::sysORUpTime.1 = Timeticks: (217) 0:00:02.17
SNMPv2-MIB::sysORUpTime.2 = Timeticks: (217) 0:00:02.17
SNMPv2-MIB::sysORUpTime.3 = Timeticks: (217) 0:00:02.17
SNMPv2-MIB::sysORUpTime.4 = Timeticks: (217) 0:00:02.17
SNMPv2-MIB::sysORUpTime.5 = Timeticks: (217) 0:00:02.17
SNMPv2-MIB::sysORUpTime.6 = Timeticks: (217) 0:00:02.17
SNMPv2-MIB::sysORUpTime.7 = Timeticks: (217) 0:00:02.17
SNMPv2-MIB::sysORUpTime.8 = Timeticks: (217) 0:00:02.17
To be honest I'm not really expert at OID numbers or what this code actually means.
Thank you.
Kind Regards,
gshergill
Can you run this
./check_snmp_temperature.pl -H <dellserver>.<domain> -C public -N .1.3.6.1.4.1.674.10892.1.700.12.1.6 -D
gshergill
Post by gshergill »
Hi scottwilkerson,
The result from the command is;
./check_snmp_temperature.pl -H grumbler.gltd.local -C public -N .1.3.6.1.4.1.674.10892.1.700.12.1.6 -D -a Temperature -w 0 -c 0
ERROR: Problem retrieving OID .1.3.6.1.4.1.674.10892.1.700.12.1.6 table: Requested table is empty or does not exist.
-a was required to run the command.
I think, as mentioned in the other thread, I will give the nagios plugins a small break and try to integrate with Munin to see how that goes. Munin seems to have some great graphs available.
For reference, this is the guide I am using;
http://munin-monitoring.org/wiki/HowToContactNagios
Thank you.
Kind Regards,
gshergill
