There are service & host status records but nothing in Core?
I delete service & host records from Core page, but they still on the detail page?
Re: There are service & host status records but nothing in C
Did you 'apply configuration''?
This happened to me before and I had to delete the service/host config files from the linux terminal.
do you mean if I didn't apply config, then this would happen and nothing can do?cellact wrote:Did you 'apply configuration''?
No, it means you will need to apply configuration before the changes take affect.xpertech wrote:do you mean if I didn't apply config, then this would happen and nothing can do?
Go to Configure -> CCM -> Apply Configuration
