I have tried to add a user in nagios XI, and I've got an error. Previously I did added the same user but I couldn’t find the user under "manage user" list. Is there any log for user creation for me to check? How can I check the user info in the backend and remove and add again?
ERROR: UNABLE TO ADD USERID: ()
Mukunthini
Unable to add Nagios XI user
Re: Unable to add Nagios XI user
Mukunthini,
Does your user show in the contacts.cfgs
Regards,
-Yancy
cat /usr/local/nagios/etc/contacts.cfg-Yancy
Lets check to see if the user is in the CCM
Configure -> CCM -> Contacts
If they are listed there you may need to remove the contact and apply configuration.
Yes I do see in the Contacts. I removed the user. Still getting the same error.
I logged into postgres backend and listed the users in xi_users table. the user was there. I've deleted the entry manually and added the user again. it worked !
Thanks all
Mukunthini
Thanks all
Mukunthini
