Nagios 3.4.1
pyshen
Nagios 3.4.1
Post by pyshen »
Hi
In Nagios Core 3.4.1 the layout for Services All changed and only displays 100 services.
For the last host that is listed at the bottom of the page instead of showing partal listing to show fewer then 100 services and push the rest down to the end?
Phil
agriffin
Re: Nagios 3.4.1
Post by agriffin »
pyshen wrote:For the last host that is listed at the bottom of the page instead of showing partal listing to show fewer then 100 services and push the rest down to the end?
I'm not sure what this question means, but there's a drop-down menu at the top of the page to choose how many services to show. If that doesn't help you, then could you please rephrase your question to be a little clearer?
pyshen
Re: Nagios 3.4.1
Post by pyshen »
Hi
Let me try to rephrase the question
So with it set to display 100 services.
My last host on the page has 5 services.
3 of the 5 services display on the frst page
2 of the 5 services display on the 2nd page.
What I am saying is it should be max of 100 services rather then 100 services. So display 97 services since with the last host not all services fit on the same page. This way for that last host it can put the services all on the 2nd page.
agriffin
Re: Nagios 3.4.1
Post by agriffin »
Okay, I understand now. Currently, this is the expected behaviour, but you can file a feature request here if you'd like to see that change.
