New install No cfg files
dxf1
Post by dxf1 »
Hi I have just downloaded the current install file and went well but none of the config files are in the etc directory i.e., contacttemplates.cfg etc how are normally generated ??
Regards Dave
mmestnik
Re: New install No cfg files
Post by mmestnik »
These files are created by NagiosQL, there is a write files tool in it's web interface the(CCM). This is known to happen on 64bit operating systems, when postgress doesn't start. We recommend using 32bit OS.
dxf1
Post by dxf1 »
The postgress service is running and I am using a 32 bit Red Hat 5.4 OS
Regards
mmestnik
Post by mmestnik »
You understand the solution I've provided?
dxf1
Post by dxf1 »
I have now cleared the box down and reinstalled linux and nagios all is well but now I appear to have problems installing nagvis and mentos it would appear that when I try to connect to the subdomin I dont always get a clean connection ?? or get connection refused
Regards
Dave
mmestnik
Post by mmestnik »
Please start a new topic for each issue.
http://go.nagios.com/faq#Common_Solutio ... hese_First
