About alert notification, what's the difference between "Core config" and "Configure"? (see attached file)
I didn't setup Core config notification, alert notification still will be send to me.
what conditions should I setup Core config notification (or something like that)?
What's the difference between "Core config" and "Configure"?
Re: What's the difference between "Core config" and "Configu
These are just 2 different ways to setup the same items.
The Core Config Manager however will give a much more granular view with many more options than the easier to use Configure screen.
If I setup the same items using Core Config Manager, will I see that items data on the other one's GUI?scottwilkerson wrote:These are just 2 different ways to setup the same items.
Yes, however some of the more advanced options won't be visible under the "Configure".
