check_jmx error Invalid credentials
westernuniv
Post by westernuniv »
I have downloaded check_jmx nagios plugin from Nagios Exchange and followed readme.txt for installation
http://exchange.nagios.org/directory/Pl ... mx/details
When I tried to execute check_jmx I've got the following message.
# ./check_jmx -U service:jmx:rmi:///jndi/rmi://localhost:8686/jmxrmi -O java.lang:type=Memory -A HeapMemoryUsage -K used
JMX CRITICAL Invalid credentials specified for administrative user
Where I need to configure credentials?
Re: check_jmx error Invalid credentials
Post by slansing »
hello Westernuniv,
As Swilkerson says belowIt seems as though the check_jmx plugin does not have the ability to add credentials you could try this:
-username
monitorRole jmx username
-password
monitorRole jmx password
Are the values you are looking for, example:
/usr/lib/nagios/plugins/check_jmx -U service:jmx:rmi:///jndi/rmi://localhost:9999/jmxrmi -O java.lang:type=Memory -A HeapMemoryUsage -K used -I HeapMemoryUsage -J used -vvvv -w 731847066 -c 1045495808 -username monitorRole -password password
This was found here:
http://code.google.com/p/jmxquery/wiki/Usage
There are a few variations of check_jmx hope this helps.
I'm not really familiar with this plugin or JMX but I did download it and look at the help file and it doesn't look like it has the ability to change credentials.
However, looking at this document
http://docs.oracle.com/javase/1.5.0/doc ... ccessFiles
it looks like you can set the credentials in a file
westernuniv
I did a search from google and got suggestions to add following JVM options to glassfish server to disable password authentication, it didn’t help.
-Djava.rmi.server.hostname=<hostname>
-Dcom.sun.management.jmxremote.ssl=false
-Dcom.sun.management.jmxremote.authenticate=false
-Dcom.sun.management.jmxremote.local.only=false
Then I downloaded the one suggested by slansing and used glassfish admin credentials, it worked.
Thanks guys!
Post by slansing »
Excellent, glad it worked out.
