i installed check_diskio in remote host workiing CLI but i can not get in nagios web
i have to manage disk io so i have installed check_diskio-3.2.4.tar.gz
it is working properly in CLI but i could not get into nagios web interface
what are the configurations i have to make change into
commands.cfg (define command)
remotehost.cfg ( define service)
nrpe.cfg
this is the output got from CLI
Quote:
[root@localhost Desktop]# /usr/local/nagios/libexec/check_nrpe -H 172.30.0.72 -c check_diskio
CHECK_DISKIO OK - sda 123.00 sectors/s | WRITE=123;4000;6000 READ=0;4000;6000 TOTAL=123;4000;6000
i have installed check_diskio-3.2.4.tar.gz through this steps
Quote:
At the Client Machine.
# yum install perl
# tar -zxvf check_diskio-3.2.2.tar.gz
# cd check_diskio-3.2.2
# less INSTALL (Read the INSTALL Readme file)
# perl Makefile.PL INSTALLSCRIPT=/usr/lib64/nagios/plugins
(You will see a list of warnings of prerequisites)
B. Install the prerequisites Perl-Modules. Here may not be completed lists.
# yum install perl-Nagios*
# yum install perl-List*
# yum install perl-Readonly*
# yum install perl-Number-Format
# yum install perl-File-Slurp*
# yum install perl-Array-Unique
C. Finally compile
# make
# make install
(You will see the check_diskio at /usr/lib64/nagios/plugins)
D. Edit the nrpe.cfg file on the client machine. If you have not download nagios nrpe plugins, just do a
# yum install nagios-nrpe
D1. Edit /etc/nagios/nrpe.cfg on the client machine,
# vim /etc/nagios/nrpe.cfg
command[check_diskio]=/usr/lib64/nagios/plugins/check_diskio --device=/dev/sda -w 200 -c 300
At the Server, just make sure you install the nagios nrpe plugins like D. Finally to ensure that the remote server plugins are ok, do a test at Nagios Server
# cd /usr/lib64/nagios/plugins
# ./check_nrpe -H remote-server -c check_diskio
CHECK_DISKIO OK - sda 194 sectors/s | WRITE=194;200;300 READ=0;200;300 TOTAL=194;200;3
please help me immediatly
check_diskio working CLI but but i cannot get in nagios web
Re: check_diskio working CLI but but i cannot get in nagios
Did you get anything set up in your Nagios configuration yet? If so, what does the web interface show?
my web interface shows
commands.cfg in client machine and servermachine
nrpe.cfg command
my clientmachine.cfg
service definition
when i am executing my command through CLI
i provide
i can get this output
please help me
i configured like this in my magios server machineDisk IO CRITICAL 08-23-2012 10:12:26 2d 21h 41m 40s 4/4 (Return code of 127 is out of bounds - plugin may be missing)
command_name check_diskio
command_line /usr/lib/nagios/plugins/contrib/check_diskio --device /dev/sda1 -w $ARG1$ -c $ARG2$
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
} Code: Select all
command[check_diskio]=/usr/lib/nagios/plugins/contrib/check_diskio -d /dev/sda1 -w 4000 -c 6000service definition
use local-service
host_name onal
service_description Disk IO
check_command check_diskio!20!50
notifications_enabled 0
i provide
[root@localhost Desktop]# /usr/local/nagios/libexec/check_nrpe -H 172.30.0.72 -c check_diskioactually i m confusing now what are the configurations i have to make in client machin and server machineCHECK_DISKIO OK - sda 123.00 sectors/s | WRITE=123;4000;6000 READ=0;4000;6000 TOTAL=123;4000;6000
please help me
