I am trying to do the login by key in userid and password to portal and handled the session object. After successful login, it will redirect to another page. Same thing, I want to do using Nagios, Is it possible?
Thanks in advance.
Session Management
Re: Session Management
Hi vijragha, can you please clarify your post a bit? I don't quite understand what you're asking.
What login method are you using? Please briefly describe the steps you're taking to log in.
Re: Session Management and Redirection of another page
Hi Support,
Thanks for your reply.
I want to use check_http
1: From Nagios call URL with parameter (eg: http://domain.com/index.jsp)
2: index.jsp: This page will do the redirect to http://domain.com/xyz.jsp. (response.sendRedirect("http://domain.com/xyz.jsp"))
Contents of index.jsp
<html>
System.out.println("In index.jsp");
<script type="text/javascript">
document.location.href="http://domain.com/xyz.jsp";
</script>
</html>
Contents of xyz.jsp
<html>
System.out.println("In xyz.jsp");
</html>
I am able to see index.jsp is getting executed based on log message ("In index.jsp").
But I unable to see xyz.jsp is getting executed. Because it is not printing message "In xyz.jsp"
Hope I describe clearly.
<html>
</script>
</html>
Contents of xyz.jsp
<html>
</html>
Hi Support,
I am waiting for your reply.
Kinldy update me.
Thanks in advance
Kinldy update me.
Thanks in advance
