How to remove a host
ndf133
Post by ndf133 »
Hi everyone,
Thank you for your reply. I have successfully install multiple monitors on a Linux server.
I made some mistakes during the installation, is there any way to remove the host?
Re: How to remove a host
Go to Configure -> CCM -> Services
Select host from "Config name filter"
Check All
next to "With Checked:" select delete
Click GO
Go to Configure -> CCM -> Hosts -> Delete (next to host you want to remove)
Apply Configuration
You remove a host via the Core Config Manager, but you need to remove all its services first. Please, read our documentation on host management:
http://assets.nagios.com/downloads/nagi ... gement.pdf
Hope this helps.
