/etc/nagios/objects/server.cfg
with the following in it. it does not want to allow nagios to run it says there is a config error.
Could someone please advise what i am doing wrong.
use generic-host ; Name of host template to use
host_name bonus
alias bonus
address 92.12.35.162
max_check_attempts 10
notification_interval 120
notification_period 24x7
notification_options d,u,r}
services config
The following should appended to the end of hosts.cfg (located in /etc/nagios or /usr/local/nagios/etc)
# Service definition for bonus
use generic-service ; Name of service template to use
host_name bonus
service_description HTTP
is_volatile 0
check_period 24x7
max_check_attempts 3
normal_check_interval 3
retry_check_interval 1
contact_groups technical,support
notification_options w,u,c,r
check_command check_http
