Not sure if this has been reported. We have a few "Recurring Downtime" setups for Services. Since the upgrade to 2024R1.0.1 (from 5.11.3), we dont see them triggering at the times its supposed to. This has been causing some un-wanted notifications which should have been suppressed.
What can I check to see whats going on. We checked the "Event Log" and dont see the messages that we expect when the downtime is setup.
Thank you,
Vinod
Recurring Downtime - not working after upgrade to 2024R1.0.1
vappukuttan
Re: Recurring Downtime - not working after upgrade to 2024R1.0.1
Hi @vappukuttan, thanks for reaching out.
What OS/version are you running?
This may be related to an issue that has been reported with Ubuntu 22 and Vixie cron.
You could try this, as a temporary work around, after making a backup of the recurring_downtime.php script.
cp /usr/local/nagiosxi/cron/recurring_downtime.php /usr/local/nagiosxi/cron/recurring_downtime.php.`date +%s`
sed -i '199,208s/^/\/\//' /usr/local/nagiosxi/cron/recurring_downtime.php
-Laura
-Laura
vappukuttan
Thank you for the quick response on this. I checked the /usr/local/nagiosxi/var/recurringdowntime.log and I do see a lot of messages with "This script is already running pid" lines. I have made the recommended changes, hopefully the next ones will start to work. I will update this thread if I still see issues.
Thank you again,
Vinod
Thank you again,
Vinod
Hi vappukuttan,
Any update on this? Curious if it worked out or not.
Thanks!
Thanks!
tgoodmanzenith
I'm running 2024R1.0.1 on RHEL 8 and was experiencing the same issue with reoccurring downtimes not getting scheduled. The following messages were in /usr/local/nagiosxi/var/recurringdowntime.log
I made the changes suggested above and now downtimes are getting scheduled correctly.
The odd thing is that if I ran the following from the command line it worked as expected and scheduled the downtime
Wed, 14 Feb 2024 08:01:01 -0800 schedule_downtimes() called
Wed, 14 Feb 2024 08:01:01 -0800 This script is already running pid: 249662 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/recurring_downtime.php >> /usr/local/nagiosxi/var/recurringdowntime.log 2>&1The odd thing is that if I ran the following from the command line it worked as expected and scheduled the downtime
sudo su - nagios /usr/bin/php /usr/local/nagiosxi/cron/recurring_downtime.phpRe: Recurring Downtime - not working after upgrade to 2024R1.0.1
In our next update we will be changing the way this process works. Currently it stops the process if there is a pid of the same cron job running. It will be changed to make a lockfile if it is running and will run after that lock is cleared. Feel free to keep an eye on our changelog for it to be released.
swolf
Locking topic and deleting the last two posts due to spam link posting
