Can't contact LDAP server
Post Reply
[email protected]
Post by [email protected] »
Howdy,
We enabled new AD GPO settings for LDAP channel binding and LDAP signing. I added the CA cert and configured our XI server for the new security and it works. I can't get the LS server to allow logins. The error is: "Can't contact LDAP server." The settings and cert are the same for the LS & XI servers.
I'd appreciate any help you can provide! Thanks!
jmichaelson
Re: Can't contact LDAP server
Post by jmichaelson »
Which version of Nagios Log Server are you using?
Here's an LDAP Troubleshooting document that we provide:
https://nagiosenterprises.my.site.com/s ... n-4057bf19
-Jason
Jacobjsdhfg
Post by Jacobjsdhfg »
[email protected] wrote: Tue Jan 30, 2024 5:05 pm Howdy,
Cookie Clicker
It's difficult to provide a definitive solution
jmichaelson
As a follow up, can you use something like wireshark, or tcpdump to capture traffic going between your log server and the LDAP server? They'll be communicating on TCP port 389 or 636.
If your log server version is new enough, we've made some big improvements in the logging of LDAP problems, so if you're not on the latest version, I highly recommend moving toward it.
-Jason
Post Reply
