Hi all,
i'm using pnp4nagios 0.6.x for creating a graph about the flexlm usage. For test-reasons i created two new Services in nagios called "FlexLM-Use-cae" and "FlexLM-Use-cae1". Both Services from nagios appear also in pnp4nagios (you see it also in the attached jpeg).
My normal live Services is now "FlexLM-usage-abaqus-cae" and FLexLM-usage-keyshot2". I already removed the "FlexLM-Use-cae" and "FlexLM-Use-cae1" checks and command definitions in nagios, but they still exist in pnp4nagios.
My simple question: How can I remove the both old Services from pnp4nagios Service Overview? I already deleted it from all nagios checks and commands definitions.
Thanks.
T.O.C
pnp4nagios delete old services
- services.jpg (12.81 KiB) Viewed 1619 times
