Nagios Plugins 1.4.16 released
cwireless
Post by cwireless »
After following this link http://nagiosplugins.org/nagiosplugins-1.4.16
just to install the new release of the Nagios Plugins.
Following the README instalation instruction , when I try to check the version of the plugin it is still nagios-plugins 1.4.13
Attached you will find the steps followed and the output for every step.
What could be missing?
[nagios@nagioscwp oc102]$ id
uid=500(nagios) gid=100(users) groups=100(users),500(nagios),501(nagcmd),503(oinstall),504(dba)
[nagios@nagioscwp oc102]$ cd $LIBEXEC
[nagios@nagioscwp libexec]$ check_nt -V
check_nt v1991 (nagios-plugins 1.4.13)
[nagios@nagioscwp libexec]$ check_http -
Name or service not known
HTTP CRITICAL - Unable to open TCP socket
[nagios@nagioscwp libexec]$ check_http -V
check_http v2053 (nagios-plugins 1.4.13)
nagios-plugins-1.4.16.txt
Output
(131.16 KiB) Downloaded 130 times
agriffin
Re: Nagios Plugins 1.4.16 released
Post by agriffin »
What output do you get when you run the following command?
# ls -l /usr/local/nagios/libexec
There are a few instructions missing from the README. Some plugins have additional dependencies and aren't built if you don't have them. For example, SSL development headers are needed for many of them. The 'ls' command above is to check whether any of your plugins have a recent timestamp.
cwireless
Post by cwireless »
Issue was solved with these commands.
./configure
Make all
Make install
Make install-root
Thats all.
[nagios@nagioscwp oc102]$ cd /usr/local/nagios/libexec
check_nt v1.4.16 (nagios-plugins 1.4.16)
check_http v1.4.16 (nagios-plugins 1.4.16)
mguthrie
Post by mguthrie »
Thanks for updating with the solution!
