Whitespace/Deadspace on Dashboards and views?
MooresLegal
Post by MooresLegal »
As per the topic title, we've got a lot of white space on our dashboards & views, specifically a large section of the bottom of the screen that seems like an artifically created edge.
@1280x1024 in dashboard full-screen mode, in a full-screen browser window, the bottom quarter of the screen space is unusable.
Does anyone know why this is the case and how it can be fixed? I couldn't find a dashboard resolution setting, or any posts here (via search) that deal with this, so I'm sure i'm just missing something obvious.
Re: Whitespace/Deadspace on Dashboards and views?
I'm not sure I understand what you are describing. Would it be possible to post a screenshot?
MooresLegal
I've posted a screenshot where the problem exists, but not as dramatically as at other resolutions.
You can see that the core server statistics dashlet has be positioned (deliberately) at the bottom of the screen but it looks like there's a hidden frame at the bottom of the screen that provents top-to-bottom content.
I have noticed that the problem doesn't exist with the latest google Chrome, so it's entirely possible it's an IE8 problem.
what version are you using? I don't see this in the latest release...
