During configuring of agent, I have option to check only 4 paths/filesystems.
Is there any way i can check disk usage of all the file systems.
Disk usage of agent
Re: Disk usage of agent
You can re-run the wizard as many times as you like to add additional mount-points. As long as the hostname is the same it will just add additional items.
srikanth.kallu
Got it
Thank You!
Thank You!
